DirtTrackRacer_07
DeeR SlayeR
If you have a bent valve, i believe more than likely one of the valves would be slightly open when it should be seated.
So it would not be letting you get enough compression and not burn the fuel enough. That would also explain the back fires.
If you have a piece of air line that has the male course thread end on the end of it, screw it in the spark plug hole and pressurize it to about 80 to 100 psi.
Make sure that you turn the motor over to where the piston would be at the top of the cylinder. You could take both the rocker arms off to make sure both of the vavles are colsed or if you dont think you can set them back you could find the compression stroke.
You will see it when you turn the motor over, watch the valves and stick a small screw driver in the chamber to feel the piston.
Watch the valves close, and you will find the perfct spot, both vavles will be closed and the piston will be round about the top of the cylinder.
Once you pressurize the cylinder, listen for any air leaks out of the intake manifold or exhaust. If you can hear some air, then the vavle is not seated, meaning eithier you have a bent vavle or a bad valve seat.
If it were mine, I would tear it down and rebuild it while I had it apart but its what I like doin.
