Jake.B
I have a few questions, First for a 5hp Briggs and Stratton with hi-flow airfilter, straightpipe, stainless steel valves, and racing valve springs. How much should i increase timing? I know you can grind the key for a cheap way instead of purchasing them is this a good idea? If it is how many hundreths or thousandths of an inch do i grind off for one degree? Second I plan on removing the govener and adding the parts to make it safe. Would the increased RPM change the amount i increase timing? I also might add a duration and lift camshaft is this another factor? To get to the key i need to remove the flywheel and it is on the shaft the flywheel rides on correct? To remove the flywheel i need a puller i have heard you can fab one up or buy one? Whats the best method to do this? I can make one im pretty sure im not exactly sure of the concept of the puller though. Is their any other factors i need to worry about?
