- Messages
- 8,359
- Reaction score
- 3,511
Common Specs For All Popular Engine Models
Model Series, Idle Speed, Armature Air Gap, Valve Clearance Intake, Valve Clearance Exhaust, Valve Guide Reject GageTorque Specifications: Flywheel Nut Ft. Lbs., Cylinder Head In. Lbs., Conn Rod Torque In. Lbs., Crankcase Cover/Sump In. Lbs.
Crankshaft Reject Size: Mag Journal, Crankpin Journal, PTO Journal
Crankshaft End Play, Main Bearing Reject Gage Or Reject Dimension, Cylinder Bore Standard
[click to enlarge]
