Briggs replacement carb and keep govenor.
freakincage
Winnipeg, MB, Canada
A brief history. I recently picked up a Bird Engineering Baja for my son to cruise around on. It didn't come with a motor. I have a Briggs Model 130232, 5hp that runs like a champ, except it needs a carb. Rebuilding isn't an option as the carb housing itself actually cracked.
I would like to switch to a float carb setup. That part is easy, but I want to keep the governor. I like the idea of my son having a rev limiter as he is still young and doesn't understand the concept of blowing a motor.
I've seen that there are people that have used those off shore carbs for pocket bikes and they seem to be ok, plus the throttle setup doesn't get anymore simplistic than that.
What are my options for keeping a rev limiter?
Russ2251
AZUSA:Powered by LAWN-BOY
It's possible to "fit" any carb you choose.
To keep the governor intact would require a great deal of linkage finessing/fitment.
Would be be easier to just limit pedal travel by adjusting throttle cable.
freakincage
Fitting a carb is no problem, it was the limiting of RPM's I was mainly concerned about. Do I need to physically remove the governor, can I just disconnect the linkage? Or does it not work like that?
I'm of the opinion that it's better to remove the internal governor guts. I've seen some pretty neat damaged caused by governor internals letting loose at higher RPM, despite the fact that the engine would have otherwise survived.
freakincage
Ok. Being that this is going to be driven by a 7 year old, what would be the best way to determine the rpm's this engine is running at? I think I'd like to keep them around 4000. Also, what Briggs carb, that is gravity fed, would be a direct bolt on? My local repair shop only wants to sell me the direct replacement carb for $140. If I have to make an adapter I will but I would prefer not to. Thanks in advance.
freakincage
This motor was off of my bosses tiller that had other issues. When his son unloaded the tiller of the truck, he simply pushed it off the truck and it landed upside down on the air cleaner which in turn cracked the carb right at the flange that bolts to the engine. I have personally used the tiller prior to it having issues.
I'm not certain about which model carb may be a bolt-on. I have a habit of just fabricating a flange and using whatever I've got.
As for the RPM range, maybe invest in a Tiny Tack. Revs can be a bit difficult to manage with throttle limiting, as the applied load will have a lot to do with RPM achived- like whether you're going up or down a grade, accelerating from a standstill, wind, friction, etc.
freakincage
I'll look into the tiny tac. I only have one carb on hand right now, from an old 1300w generator. The plan is to use the fuel tank, but nowbmaybe the carb too. I think the bore may be too small though. The Briggs bore is 3/4" and this one is 5/8". What are the thoughts of using this carb?
qtband
St. Louis, MO
You could try to clean the cracked area and JB Weld it or use steel putty. Worth a shot. That stuff works on a lot of things.
freakincage
I'm a huge fan of JB Weld, but I think that this repair may be a bit too ambitious for it. I'm still looking into other options, like a carb for an offshore pocket bike. I also have a 6.5hp Honda (not a clone), but I was hoping to use that on my mini chopper...
solomon
ca
if its not a performance build. Why don't you run a stock 5hp pulse jet carb. If you want to run a float style carb. that bad then you need to loose the gov. IMHO if its just a kids mini bike the pulse jet will suffice with no problems. Ebay has them for around &5 rebuilt and ready to run from when i last checked. ANYWAYS if u put a float style carb on it then u have to modify your current fuel tank AND mount it above the carburetor to work, unless your using an external fuel pump of some sort...
EDIT:$75 - regarding the carburetor price
freakincage
I was able to get a float carb from a local power sports dealer for $25. They have a "bone box" in the shop that's full of different new carbs with issues and they don't bother messing with them. This one leaked from the bowl gasket and the fix was tightening the screws. It has a 19mm bore. I made the manifold from 3/4" black pipe and 1/8" plate. It's not pretty, but it gets me up and running. I still have to remove the governor.
freakincage
I think this carb was for a 110cc and the Briggs is a 206 (according to the interweb). I'll see how it runs once it's on the kart. Who knows, it might work out well enough...maybe a bit lean though.
solomon
ca
Congrats on the carb find and the intake manifold. Time to pull the governor. If you follow my sticky on it you should have it removed and safely back together in less than 10 minutes
freakincage
I've read the sticky and removing the governor is the next step. I'm on the fence on whether to use the original governor shaft or thread the hole and loctite a bolt in there. What are the thoughts on this? Is one option better than the other, or is it just personal preference?
solomon
ca
I always leave the shaft and grind the "flap" off of it. That way it looks original on the outside still plus i didnt have to get a bolt a tap a drill or loctite. But if you already have the bolt and tap and loctite on hand go for it.
