Briggs Problems
Budzeno
Dirty Jerz/ Pocono PA
I got this briggs engine and i ran it pretty hard today. At one point it started to smoke from the clutch. It wasent alot o smoke, so we let the engine sit for a while then fired it up about an hour later. Then the kart got tipped on a sharp turn. By the end of the day it seemed to keep stalling out when earlier it ran perfect. I was wondering what yall think the proBlem is? Is there a clutch problem? Or was the roll the cause of the enging stalling? Im a newbie so im very lost here haha
There's the potential for two problems here-
1) Smoking clutch generally indicates an overloaded condition, brought about by an inappropriate gear ratio or driving conditions. OR there was oil on the clutch, caused by a spill, leak, or over-oiling the clutch bushing
2)If you rolled the kart and now it stalls, look for two things- You could have lost some oil in the roll and the low oil sensor is activating. Check oil. Other possibility is that rolling it did something to the carb- perhaps the float was knock out of whack or some debris entered the carb.
Budzeno
Ok sounds right the clutch also makes like a high pitched sound, but its barely knowticed. I dont know if this helps determine the problem.
If the gear ratio isnt right how do i tell and what steps are there to fix it.
Budzeno
Ill post more info on my kart in the morning cause it over at the gee-raj. I wana get these problems fixed so i can cruise wothout worry of dragging the kart a mile back to the truck. (and so i can start the next "project") haha
Also i have another briggs on the other kart and the pull cord constantly frays and snaps. And i mean daily, its a pain in the ***. I looked for sharp edges or anything capeable of cutting it and couldent find a thing. Can anyone recomend a differt option theb usin thw standard "rope" pullcord. Maybe something that wont fray?
