Briggs idling high
Devon95
Illinois, USA
Vertical shaft briggs is idling ridiculously high.
Two screws on top, left is mixture, right is jet.
Bottom there is another screw with a spring, and then theres that end on the fuel line that twists. Someone give me proper adjustments? Ive adjusted carbs but this one has me lost.
  • 5E459033-9D13-45CD-B0A2-BC0E0B3B0053-12266-000008F031704A90_zps352600ca.jpg
I edited your post, and fixed your link, wasn't working...
Now- your carb's a bit buggered up. See that screw in the foreground of the picture, right behind the fuel valve? THAT is your idle speed set screw, and there should NOT be a cable or linkage hanging off of it. On the opposite side of the carb (same shaft) is where the throttle connects to the governor.
The main jet needle mixture screw is on the BOTTOM of the carb, in the middle of the float bowl.
On top- the screw on the right, is actually your emulsion tube (keep it snugged up) and the screw on the left (IIRC) is the idle mix.
I'm looking at one right now- Had it in my scrap bin, and my scrap guy hasn't come yet. Mine's off an 8hp Briggs vertical, circa 1972 (IIRC)
