Briggs flywheel on Tecumseh?
vwmopar
I have a Tecumseh H60 that I'm trying to build up. Is it possible to put a billet 3hp or 5hp flywheel on it. I know the taper is different. If so does anyone know where I could get this done? I have both points crank and solid state ignition.
vwmopar
It requires machine work. I I will be attempting it. Just looking for options.
vwmopar
I know people have done it but now that the ohv motors are out the flatheads are old tech which parts and info are somewhat lost.
Poboy kartman
Senior Moments Member
White Settlement Texas
So.....you want to put a Briggs flywheel on a boat anchor?
JK....But just barely.....Tecumsehs are good engines....but you can get more for less with a Predator.....
Good luck and keep us posted on what you do and how it turns out....
Besides the taper....I would compare...magnet and keyway locations....just to be safe....
vwmopar
Predators are ugly. If they leaned the other direction it wouldn't be so bad. A lot of mini bikes wont fit the clones because of the lean. This also creates a problem if you want to run a torque converter set up.
No not really. Do a search on clones and such, find plenty TC/clone combos, even cent clutch/clones.
There are plenty of bikes with this motor running this motor, I have 3 motors, 2 mini bikes running clones.
vwmopar
That's because you made it. The OHV engines just don't look good on the old bikes. That's my opinion. Try running a clone on a Harrison wildcat with a torque converter.
