Briggs compression?
sideways
Unfinished projects king.
Perth, Western Australia
How many PSI of compression should a Briggs have? My vertical shaft briggs that I'm converting to horizontal shaft (see here for more details) had just below 60 PSI of compression when slightly warm, how much do briggs flattys normally have? I'l get the engine hot and then do it again.
Thanks
Hayden
Kenny_McCormic
Kartless....
Michigan Troll
You cannot measure compression on a flatty using normal methods due to the decompression system. You need to crank it over backwards. Briggs doesn't even outline doing a real test, their procedure is to throw the flywheel at the compression stroke, if it bounces back you are good.
jr dragster T
Cold place
Last time I've seen a briggs 5 hp cam there was no easy start.
sideways
Hmmmm I didn't know that, the Briggs I've pulled apart (a relatively new 3hp flatty, an ancient one with up draft carby and the remains of a mower engine that had smashed a piston) didn't have any form of decompression system? and this mower engine has a approximately 3:1 reduction in the pull starter and you can still feel the compression so I'm sure it doesnt have one. Anyways, we'll see when I pull it apart..
Thanks
Hayden
Russ2251
AZUSA:Powered by LAWN-BOY
Valve overlap...or...intake and exhaust are both open at same (very short) time.
Is easily observed through breather opening or can remove head.
Intake valve begins to open before exhaust valve is completely closed. Becomes a non-issue when operating rpm is reached. Gain is insignificant if this feature is disabled.
Simple stuff.
sideways
Simple stuff.
Lots of engines do that? Its part of the scavenging system? :huh:
Are you meaning on compression stroke or between the exhaust and intake stroke?
Either way, the decompression system sucks (if it is in fact exists) if I got just over 60 PSI :huh:
Thanks:cheers2:
Hayden
Russ2251
No valves should be open during compression stroke.
I mean when exhaust valve is closing and intake valve is opening. Exactly as I stated. This only happens once every 2 complete revolutions.
Exactly the point of "Easy Spin". To ease starting, compression must be lowered (released).
Do as Mr. McCormic correctly suggested. Spin it in reverse!!!
sideways
Exactly the point of "Easy Spin". To ease starting, compression must be lowered.
Okay, yeah thats what I thought. I thought you were meaning both valves were open on compression to act as a compression release which I thought couldn't be right lol. And yes, I know almost all engines have valve overlap, more overlap is better for power, I don't see why any one would get rid of it...
Hayden
