Island kart
- Messages
- 14
- Reaction score
- 0
Hi guys
My 6.5hp engine was running like a dream eventhough it had been sitting for about a year but then i decided to remove the governor cam inside the engine, did all that was said removed the cam plugged the hole ect. the cam and rods fell out but I put both back and lined up the dots perfectly. Then I sealed it all back up put some 10w 30 in it and it fired up fine but it wont idle. I then worked on the idle screw and cleaned the carb several times (with pins and water and degreaser) let it dry and put it back on, runs a little better however I still cannot get the engine to idle below the clutch engaging no matter how hard i try, I can get it almost there and then if i leave it, it will splutter and die.
Only thing I can think of is filling it up completely with oil (a cm from the top) and running a health dose of carb cleaner through it.
Also when its about to die i get some nasty smoke from the muffler.
Please helppppp!!
Thanks
Please helppppp!!
Thanks
