o2jmpr
Hey all. I’m in need of your knowledge.
I just rebuilt a new to me Briggs 5hp model 135202. Everything looked really good and is in specs. I lapped and adjusted valves, new gaskets everywhere etc.
The engine will only run strong at 1 very specific point at about 3/4 choke while sitting in the bench with no load. It dies at full and dies at “run”. I’ve torn the carb off 3 times now and poked every port, flushed with aerosol carb cleaner and blew with air compressor. I’ve also added a good amount of sea foam to the gas and let it run a while. It has new springs and diaphragm. This behavior continues at any idle setting and it will run with the idle adjustment anywhere from 1 turn out to all the way out. I set the governor and found that if I hold the slider on the bottom of the tank assembly where the governor arm spring and throttle linkage is with jus the smallest amount of pressure then the engine will run (albeit roughly) with the choke completely off. If I move the choke back to the 3/4 open position it likes it will run smooth and hard again.
This still seems like a fuel delivery issue. I’ve sprayed all around and can’t find an air leak anywhere but I can’t possibly get this carb any cleaner. It wasn’t dirty or varnished to begin with when I bought it.
Anyone have words of wisdom other than buy a new carb? THANK YOU!
