Without measuring its hard to tell. check the jet size, as .036 stock jet for gas. .050 jet for alchy. check the dia. of the cat eyes, small hole if a #71 drill bit using the shank end will go its an alchy carb. Large hole check with a #.053 drill bit. alchy carb. Turn the screw in by hand until it stops and turn out 1 1/2 turns.
By brass screw, I hope you mean the jet. If so, clean it real good some times they are to read. A standard gas jet will stamped .036 or maybe .039. and most are either stamped on the top (slot end) or on the side.
Well I am not going to state that no number is a rarity, but it is highly unusual. Do you know anyone with a number drill bit set? If so see if they can check the size. That will be your only way of knowing the jet size.
taylors around the corner didnt have a bit small enough to size it.
on another note; can someone please tell me what throttle cable to buy for this setup. all i have on my motor is the metal L bracket looking piece and i need a throttle cable from my pedal to the engine.
For you folks looking for alky fuel,
call the local drag strip.
If they run junior drasgsters, they will know where to get fuel. Or know some one who does.
tap
