Well... got new clutch on and everything hooked up and pulled about 8 times with no start. Then the engine completely locked up. Pull start won’t move at all. Any ideas of what the issue could be on this ?
If it was working fine before you replaced the clutch, and wasn't even run after the replacement, then something points me to the clutch??? Did you take it off and try turn the engine? Is the entire drivetrain hooked up at the moment?
