Briggs and Stratton 8 hp horizontal replacement bolts
sum_guy55
I'm looking for replacement bolts for my horizontal shaft 8 hp motor. I need he bolts that hold the cap on to the block as when i got the motor 2 were broken. and one of the threads on was completely stuffed. Is it ok to re tap it to the next size bolt up and use that?
Thanks.
freakboy
the names 'mater
hick town
dont be a dumb *** and use normal hardware for head bolts...get the pourpose made things and be done with it...
fowler
Bullsbrook West Aus
is he missing head bolts or bolts that hold the metal/plastic cover on
if it is the head then u must go to a briggs supplyer and get the propper bits
theo
Use proper head bolts and see if you can install a helicoil in the striped head bolt hole.
