briggs and stratton 136202 throttle
DrD
Edmond OK
I just cleaned the carb on my sone b&s 135202 and even thing moves free and easy. BUT now the throttle stays wide open. Where or is there a return spring that springs it back to idle once the gas pedal is no longer depressed?
DrD
Edmond OK
I have combed through the pics and carb diagrams and not seen a return spring. I am not sure if it is on the carb or the governor arm.
DrD
Edmond OK
There is a small hole near the end of the governor arm. I was able to attach a small spring running from there to the a bolt on top of the engine. I did not see a tab or holespecified this. It works great at holding up the governor arm and closing the throttle. So
DrD
Edmond OK
I dont believe the return spring is on the carb but between the tank and motor attaching to the governor arm. It is difficult finding any pictures or mention of this online.
