I have searched on the internet and cant seem to find the idle speed of these engines. Ive seen 1750 RPM but that seems to fast correct me if im wrong.
The reason I ask is that it's pointless to fret over idle RPM spec if you have no way to measure it. Just adjust it so that the kart does not try to creep forward at idle (including choked cold starts).
Whichever standard, off-the-shelf clutch you choose will be compatible with your engine (be sure to order correct shaft size).
If you wish to do static RPM adjustments, I would recommend a digital strobe tach.
I use a Extech #461830 Digital StroboTach.
At about $250 is well worth the price.
