briggs 8hp problem help needed
panman9
hello all i have a 8 horse briggs which ran fine a couple of days ago but now when i turn it over it makes i squeaking noise from te carby(its a updraft) i pulle the carb apart and i found out that it is blowing air from the intake which is causing the noise , my question may be stupid but im wondering if its ment to do that and if not what the causeof it is. the weird thing is that it ran fine acouple of days ago(havent tried to start it just turned it over) and the valves have been done and it has great compression, so im stumped any help?
panman9
the exhaust is fine, no i did not do th valves, someone else did, but nothing has been changed since a couple of days ago when it was working
panman9
na i cecked by sticking my finger in the inlet and the valve moves, plus the engine still has good compression
