MancoGX390
Just tinkering...
Hi guys, I'm needing your opinion on weather i should keep or sell the old Briggs 8hp flathead that came on my Manco Dingo which i swapped out for a GX390. If you put a teaspoon of petrol under the spark plug then screw it back in and pull the starter cord it will fire right up first pull but it dosen't idle very well. It needs a lot of work, the engine is very worn and probably needs to be re bored and have a new sleeve installed and all of the stuff that goes along with doing that but what do you guys think? Bearing in mind it will probably cost me about £150-£200 to get it properly working again. Is it worth it?
