Briggs 6.25 problems
carter
I have a mower with a Briggs 6.25 (I'm aware this is a kart/bike forum but this is the only reliable source of engine help I can find) and when I press the prime button, nothing happens. I put gas in the tank and pushed the prime button nothing happens like it is just sucking air. the gas line is very old looking and appears to have visible cracks all down the length, could the origin of my problem just be a bad line?
r_chez_08
Should be in the shop...
Cornwall, UK
It may be, I would replace the gas line and primer bulb if it looks cracked. Check gas is acually getting to the primer bulb.
carter
after letting the gas sit for a bit it actually seems to slosh just a bit, but nowhere near where it should if it was actually filling with gas.
forgive me for calling it sloshng, the bulb feels like it has filled a bit and is pushing some gas out, just not much. I also took off the cover for the airfilter and pushed the button and saw where the gas squirted out. there wasn't much coming out at all, video in a bit
