Briggs 5hp Issue
qtband
St. Louis, MO
This 5hp Briggs wouldn't idle. It also had a very carbonized plug. I bought a new carb and installed it. It idles and runs well but there are 2 issues.
1. When you rev it up and release the throttle, it dies. It starts right away again, but does the same thing.
2. After I clean the plug and run it for a couple of minutes, the plug is black again.
Any answers?
The carb only has an idle adjustment.
Everyone likes pics, so here's one....
Kansaskart
Wouldn't cost much to start with the easy stuff. See what a new spark plug does. Probably not much lol. Also, is that a brand new carb, or just new to the engine? Before getting carried away might check the compression, or find someone that can. That carb runs off a diaphragm if it's low it won't run right. Knowing if the ole boy is worn out and needing rebuilt will save you a lot of time and frustration. I learned that at age 10 when I had every new external part possible on my 2hp Briggs before someone told me about compression and that I had near zero.
Also, that carb does have another adjustment I see it in the pic. Turn it all the way in, don't tighten just till it stops, then back it out 1 turn. That and a plug would be easy and cheap to try.
Kentucky Boy
Bowling Green, KY
The old Briggs might need the valves cleaned and re-lapped. If the plug gets black that fast I'd say it's running very rich or the rings are shot.
qtband
St. Louis, MO
Thanks for the ideas. I'm taking it off the kart and putting a new Ironton on it. In the winter, I'll tear it down and rebuild it.
