Young One With A Manco
Please view pictures here;
http://www.diygokarts.com/vb/album.php?albumid=1200
Hi again all! Long time no see.
I am trying to get another race kart going. I have the motor running, but can only get it to start for no longer than 10 seconds. I'm assuming this is because i can't submerge the bottom of the float bowl on the carb. I've been running it with the gas tube (white off bottom of carb) in a jerry rigged temporary water bottle gas tank. The time i had it running the longest, gas was filled all the way up to the float bowl.
Now, clearly my gas tank is rusted beyond use inside. I can't find a new one for less than $75 online. Here's an amazon link:
https://www.amazon.com/Briggs-Stratton-694315-Replacement-Models/dp/B002WNUA76
I can't justify the cost of a whole predator on a single gas tank. I can't even be sure it runs well, never has run for more than 10 seconds. That being said, where do i go from here? I need to use the tank to have the float bowl submerged. I can't use another tank. That tank is shot. I don't want to spend the money on a new tank. Any temporary tank i can make to just to see how it runs? Should i buy another carb for a briggs, then run a fuel line to a separate tank on the frame?
Any thoughts appreciated! Thanks!
