briggs 5 hp rod bolt torque
Garified
I like to move it move it
SC
Working on moving engine internals without a torque wrench is like playing russian roulette. And Blue, you've been lucky.
Just go invest in a torque wrench. Preferably the "Pull till it clicks" type. You'll thank yourself in the end.
sideways
Unfinished projects king.
Perth, Western Australia
Im more concerned about headbolts than anything else.
Head bolts are probably the least important thing to torque.....
Over tightening the rod bolts will cause the tolerances to be too tight, this will lead to a starvation of oil at high rpms, leading to the bearing binding and snapping your con rod thus throwing it through the block.
To loose has already been discussed.
Thanks
Hayden
