Briggs 5 hp connecting rod.
frankjc
Hi. I have a Manco go kart with a 5hp Briggs and Stratton engine.
The connecting rod has snapped. I have a few lawnmower engines kicking around. I am wondering if the rods are the same on vertical shaft engines as on horizontal? I don't know if this is a dumb question or not. I know a new rod is short money, but I like to reuse/repurpose/recycle when I can.
Thanks.
The rod cap will be different; a horizontal engine will have an oil slinger, a vert will not.
Providing they're the same spec engines, they should be, at least, close; take some measurements & trial fit everything to double check
frankjc
I am not sure what condition the cap is in. Its floating around in the crankcase somewhere....I pulled the head off last night and pulled the piston out, one side where the bolt threads in is broken off and the other bolt seems to have worked its way out.
I personally wouldn't be keen on mixing and matching rods and caps. If you get a rod out of a vertical shaft engine with no oil slinger on it, study the old oil slinger and duplicate it as best you can with some 16ga sheet metal or similar. While these engines may not be the highest tech or built to the tightest tolerances, there's just a part of me that coughs up a hairball thinking about using rods and caps that don't "belong" together.
frankjc
here is a picture inside the crankcase....does that rod for the governor look normal?
I saw a sticky about eliminating it, what are the pros and cons of doing that?
frankjc
and here is what the connecting rod looks like now. it says 5hp, 206cc on the pull start cover.
Yes, that governor arm looks right. I have a 12hp Broggs L-head vertical on my bench right now that I'm working on- looks just like that inside. In order to get that apart, you would have had to lift the governer gear and flyweight assembly off the camshaft.
zbuck
Ft. Wayne, IN
:wai: I would question what caused the rod to come apart. Dirty oil, low oil or govr'n gear failure. Evidently it was not the sheet metal slinger because its still in one piece. Its hard to tell from the picture but looks like some gualing on the crank throw. As far as using a vert rod in a hort'z engine, it probably can be done. But to me its not worth the time and effort, Pull the crank and clean it then mic the throw to see if it is in spec. You may find your problem there. New rod or after market rod will not break the bank so get a new one. Also which ever way you decide to go, check the oil clearance between the rod and the crank throw. While your in there I would put a new govr'n gear in just to be on the safe side. Just my 2 cents worth.
frankjc
Hard telling what happened. It was broken when I got it. All that was in it for oil was a little sludgy residue in the bottom of the crankcase. I don't know if someone drained it before I got it. The bolt on the bottom of the picture seems to be in good shape, I was wondering if it fell out, and maybe the other one got bent, then broke the rod.
The crankshaft doesn't look too bad so far, but I have not taken it out yet. I will clean it up and see if it's useable, if not I'll look for a replacement. I have another engine I might put on for now until I get this one working.
Scout
Nutjob
Indiana
What is your location? I'll be replacing a 5 hp Briggs this winter. Nothing wrong with it, just wanted a newer motor that would keep up with my friends.
frankjc
I am in Massachusetts. I have a motor I may use. If it doesn't work out, I may be interested.
