Briggs 3HP won't rev
The Briggs that I have on my minibike is now giving me hassles. I had to replace recoil on the engine, so it stood for about a month and a half not going.
I eventually get the recoil sorte out, put it on the bike, and everything seems to be OK. I drive it once down the driveway, and it looked as if everything was good.
Because the bike had been standing a while, I decided to give it a wash. I pull the hose out and start washing, trying not to get the engine wet at all. After I washed it, I could start the engine and it idles perfectly. As soon as I want to rev, it loses power and starts to die. If I keep the throttle open it dies, but if I leave it it idles again.
I had a look to see if any air was being sucked in through any of the gaskets, but they look fine.
I am assuming that I probably have to clean the carb, but before I pull it off, I thought I would see what everyone else thought.
Could it be some water got in the gas, or the air filter got wet (dont think so cos it is still doing the same thing and it is dry now)?
Thanks in advance
klicky96
Sandusky, Ohio
Take the tank off of the carb, empty it out, clean out the float port, replace that gasket(I replaced mine with cork gasket) and it should run great.
flowerman
junior member
England, surrey
I agree with all of the above but how long are you running it at idle before you start to try to rev it? I have the exact same engine as you but mine in just sitting around not in a bike or kart and I don't keep much gas in it and I start it once a month just to check it is ok. But I have to let it idle for around 2-3 mins before it won't cut when I rev it and when I rev it for the first time I only open the throttle about a quarter because if I give it any more it will cut out immediately.... Could fix it, bit of a pain but it's not really in use... And can I be botherd? No
Actually just had a thought you may want to replace the gas in it it may be old seeing as you have not run it for 11/2 months. These days petrol goes off very quickly.
Btw that's a sweet bike:drool5:
r_chez_08
Should be in the shop...
Cornwall, UK
Once I was riding my mini bike in the rain, and some water got on the spark plug, causing it to short (only when revved up for some reason?)
It only takes a minute to take off the spark plug cap and dry it off, may be worth a shot?
Try running it without the air filter.
I'd say the air filter is the problem. :thumbsup:
I will try this when I get home. The only problem is that my frame is so tight there that it is nearly impossible to get it off without taking the tank off. I will give it a go though
I had the carb cleaned several times last year, so i doubt it is that. I am not ruling it out though. This engine has been tempramental since the beginning.
Thanks for that. You can check out the build log that is in my signature.
I have let the engine idle for about 10 minutes, and the problem still persists. If the other suggestions don't work, I will let it idle for longer and see what happens.
first pull the air filter and see what happens. then go to carb cleaning. try the easy **** first
I agree. That is why I thought I would ask your opinion before I took the carb off. I don't want to go to all that trouble if I don't have to.
This is a really good suggestion. It will be the first thing that I try. Thanks
unsrew the main jet and check for blockage?
Will do. Thanks
Any more suggestions?? I will only be able to try all of these when I get home from work....and I have just gotten to work. Still 8 hours to go..... :mad2:
klicky96
Sandusky, Ohio
The carb is not what needs cleaned. your not understanding what my post said. There may be water in the float port. The float port is part of the tank itself.
AAAH, I see what you are getting at. I'd hate to have to take the tank off and check, but I suppose I will have to if nothing else works. Thanks
klicky96
Sandusky, Ohio
Its an annoying fix, but its not that hard. I had an old briggs 5HP that happened to d the same thing. But I didn't spray mine with water. I took the tank off, looked into the float port and couldn't tell. I emptied it out into a container, then I could tell. I also replaced that gasket with a cork gasket.
Thanks for all the help guys. I got it sorted. It turned out that i just had to increase the idle a bit, and then the engine revved up fine. I think it was getting starved of fuel when using the throttle. Thanks again for all the help. Hopefully this thread helps someone else.
