Briggs 3hp spares
r_chez_08
Should be in the shop...
Cornwall, UK
I have tried to get this engine running but have had no luck. Probably blocked carburettor and the damaged block.
Parts:
head, good condition, just a bit dirty, and includes bolts.
Carb, very dirty, will probably work if cleaned well.
Fuel tank, good condition, just been painted silver. Bit dirty inside
crankshaft, good condition, except from slightly damaged removing a pulley, but still usable.
Camshaft, good condition
rod, good condition, includes dipper and bolts.
Flywheel, good condition, apart from surface
rust. Includes flywheel key, and nut, and recoil parts
Piston, needs new rings, as one is broken, a few scratches
recoil shawl, needs painting, and cleaning. A bit rusty.
Block, could do with a good hone/ bore and the bushing is very loose. Also the exhaust is rusted onto it,
block front/ crankcase cover. Good bushing. Needs repaining.
coil points ignition, may ot may not work, produes spark.
Please note all parts are untested, as I haven't ran the engine, so therefore no returns. I have tried to describe each item as accurately as I can, but I do not know the history of this engine.
r_chez_08
Cornwall, UK
I don't know what any of this is worth, so give me an offer :) btw the carb will probably need a good clean, and maybe a rebuild also.
