Briggs 3hp model 80200 problems starting/running
hammy
United Kingdom
Hello :)
I am looking for a little advice please.
I have a 3hp Briggs and stratton engine that is on a rotavator/rototiller and it is VERY temprimental. It will run sometimes then it will not run or start. I have taken off the carb and replaced the diaphragm and cleaned the carb with carb cleaner and still cannot get it to run or start. I have tried putting fuel in the air intake to prime it and it runs from the fuel that was used to prime then stops. We have cleaned the fuel uptake tube that is situated in the fuel tank so that is not blocked. The tank looks reasonably clean. It has a good spark and compression.
I cannot understand what is causing this.
Any advice would be great.
Thanks all in advance.
hammy
United Kingdom
Thanks for your reply.
I have cleaned the carb again and had the main jet out and all of the holes have been cleaned with a fine wire and a new diaphragm fitted properly. I now find that it will run with Choke on only when the choke is pushed it the engine will die.
Any ideas why this happens? It cannot be a dirty carb as it has been fully cleaned 3 times.
B.M.800
TheBeal.
Central PA
Maybe the carb needs adjusted?
If you took the carb apart, including the adjustment screws its entirely possible they are over/under adjusted causing your troubles.
hammy
United Kingdom
We have taken the screw out 1.5 turns as recommended by Briggs.
We have also taken it out by 2.5 turns. Still it will not run under load with the choke in.
Poboy kartman
Senior Moments Member
White Settlement Texas
While the exact cause is not always easily identified....the condition that is causing the problem is.....
INADEQUATE FUEL DELIVERY! Most likely cause....a blocked passage in a dirty carb......
Maybe not.....but.....
Did you boil the carb in lemon juice?
Is it possible you have missed a passage.....Seriously, you can clean the same passages and areas 10 times.....if they aren't the problem, then you haven't done anything.....
It's like cleaning your carpet....but your house still smells....because there's a dead cat behind your couch that you didn't move....
lances21
Make sure the carb to head gasket is good. When it is running spray starting fluid around it to make sure it doesnt suck the fluid it. does the carb have a main butterfly? check that for correct closure or opening
Does it have a shallow or deep tank? Some years ago, I learned that the engine simply will not start unless a deep tank is at least 3/4 full...
hammy
United Kingdom
Hello :)
Thank you all for your replies it is most appreciated.
I would like to give you all a little update. We fitted a different Carb onto the rototiller and it fired up on the second pull of the starter which was a complete and utter shock :smiley_omg: it has NEVER started from cold without priming before. So it shows that if you have a good carb that the engine will fire on second or third pull. It is a matter now of working out why the original carb does not work as we have cleaned everything, had the jets out etc. No hole has gone unpoked or unsprayed. I have another little query but I will make a new thread for that one :)
Again thanks and it was the carb ;)
Poboy kartman
My money is still on a dirty carb.....
Send payment to the 'Poboy Fund'.....flat beer is an acceptable substitute for cash.....:cheers2::lolgoku:
Glad to hear you got it going....my neighbor's took a few more pulls and still has a slightly rough idle....but it was a rust bucket....and the replacement carb was about $100 online...so....for a $20 rebuild kit....I was happy I was able to get it going for him.....
