Briggs 3.5 not staying running
Duckhunter
Hi, i have a 3.5 hp briggs engine model 91202 type 001601 code 970429fa. It will only start with choke. But when i try to move the choke lever it sputters and dies. I have replaced the spark plug. Gas is good. Any suggestions? Thanks in advance.
P.S. is normal steel conduit galvanized.
Duckhunter
Thanks and it was the fuel air mixture being too rich
Sent from my LG-US780 using Tapatalk
---------- Post added at 07:08 PM ---------- Previous post was at 06:38 PM ----------
I know that welding galvanized pipe is bad but can I use it for the exhaust without wielding it or will the temperature be too high
I made my exhaust for my bike out of EMT, you do need to grind off the galv to weld a joint, but I'd say it be recommend to just remove it all off. It will smoke eventually and those fumes are bad.
Duckhunter
Also I do not have room for my airbox cover as the frame is on the way I need just two inches or so to clear it any suggestions
Duckhunter
I will post some pics in a little while as I have an interview soon.:)
