Briggs 18hp Opposed charging circuit?
newrider3
Colorado
I've just redone most of the wiring on a riding mower with a Briggs 18hp Opposed twin (may make a separate thread later), but I still need to hook up the charging circuit. There is a connector with a red and a black wire coming from the charging coil. What (if any) kind of controls/rectifier/whatnots do I need to have in the charging circuit? Anyone have a wiring diagram? Thanks!
BriggsTwins
Pittsburgh pa-Tallahassee- fl
there has to be a diode with a high enough current rating for the engine's alternator. if there is one in place you will see it covered in heatshrink. if so, you can run the alt to the positive side on your selenoid, the side with the battery
