Briggs 1350 Intek
boogieman98
Texas
I have just received a brand new Briggs & Stratton Intek 1350 engine that I am trying to put on an old Manco Go-Kart that was powered by an old 5 hp Briggs & Stratton. The issue I have which I assume is common is that this engine does not have a remote throttle capabilities. It has the Rabbit/Turtle Speed as well as a choke. I want to convert it to the remote throttle but dont know how I go about doing this. Any help would be much appreciated. Also Do I need to remove the governor?
boogieman98
Texas
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Just hook the throttle Cable to the Turtle Rabbit Lever.
Loosen the Nut, above what looks "Goldish" color in that Pic
add a return spring to pull it back to idle speed.
You Do not "NEED" to remove the Governor.
Poboy kartman
Senior Moments Member
White Settlement Texas
"It'll be fine..."
I'm not that sure what I'm looking at. I think the long rod on the left goes into the flywheel cover and hooks to a fin that moves when yhe air pressure of the spinning flywheel fins put air pressure on it. The lever with 15 holes controls how high the revs can go before the flywheel gov can override the spring tension.
But I'm not really sure what hooks up to the carb...and what yhe bolt on the left does...looks like a Tecumseh internally activated govenor.????
So...while what Chancer says makes sense...I just can't see enough nor do I know enough about this paticular engine.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
It looks very similar to my 5.5 Brigs intek. Before I removed the governor and its linkages.
and that was also how I originally hooked up the throttle.
