Not necessarily bad, the crankcase is continually sucking-n-blowing air in-n-out of the breather. It should be either hooked up to the air cleaner or have a filter on it because of that.
Were you riding on particularly rough terrain? Is your oil level maybe a bit high? Are you running well above 3600RPM? Any of these can be contributing factors.
Yeah the terrain was super rough. It is entirely possible the oil level is high, as I just put the engine on a new 15* motor mount. And I have no idea what RPM I'm running at, it is a ungoverned predator 212.
Oh, a Preeeedatorrrrrrr??? Well, that's different.
Not really, although I was thinking flathead with a breather / oil separator... You mean the tube coming out of the valve cover, yes? It'll help to have it pointing upwards, so's the liquid drops run back into the engine. With a filter on the end.
