Brakes
B.M.800
TheBeal.
Central PA
So, the kart I have has brakes very similar to this: http://www.mfgsupply.com/m/c/AZ1822.html
My engine I want to put on is about 1 centimeter to wide and the brakes are in the way.
I was wondering if this would be a good replacement: http://www.mfgsupply.com/m/c/4-488.html
I dont know how big it is, but im thinking it wouldnt interfere with the motor.
Would this work? If a picture of my kart would help, I can try to get one.
Thanks!
r97
Measure twice cut once
Massachusetts, USA
pics would efinatly help, that caliper should work just as well, but it may be to big for your aplication, pics would help
Blazkowiez
Kart Aficionado
Houston, Texas
The second picture of the mechanical caliper you have in the link is complete trash. There are many better set-ups that will work for you. I'm still a strong believer that band brakes if applied correctly are the cost efficient champions of karting.
anderkart
Surprise Arizona USA
What portion of the engine is too wide and contacts your current brake setup? (could your old brakes be moved over a little?)
Another option might be machining/modding your motor mount to move the engine over 1 Centimeter. To compensate for this you'd also need to adjust or shim your rear sprocket over the same amount to line up again.
B.M.800
TheBeal.
Central PA
OK, lets see i I can get these pics to work...
Maybe again... OK I keep getting upload errors... what do I do?
Its up against the cover for the pull start. The brakes on it are welded, and cant be moved easily.
We were thinking about drilling out an adapter plate sort of thing...
anderkart
If you only need 1 centimeter of extra clearance how about simply bending that arm away from the pull start cover just a little bit. If you unbolted that clevis you could slide a piece of pipe over the arm and then bend it out a little. If you've got access to a torch it might be better to heat it up first but it looks like it would probably bend pretty easy cold.
r97
Massachusetts, USA
yea bend the brake lever away from the engine a bit then you could maybe re-drill the holes a bit over in the brake caliper arm.
r97
Massachusetts, USA
bend it above the weld joint, bending it shouldn't weaken the metal, unless you bend it over a ton you shouldn't loose more than a 1/4" on the brake arms length, if you want you could weld in a reinforcing piece but its prob un-needed.
brilamb2
ive had to do stuff like this to snowmobiles before. If you bend the red arm over just about a 1/4", you shouldnt have any real loss in leverage, and as long as you dont bend teh weld, the temper of the steel wont really be affected cold, only slightly if u heat it.
B.M.800
TheBeal.
Central PA
Thanks for the input guys, but we are going to just make a adapter plate. It helps when your older brother works for a precision machine shop!
Ill try to get some pictures when its done.
Thanks again!
Blazkowiez
Kart Aficionado
Houston, Texas
There is something about that kart that makes me think its a Ken-Bar that's been heavily modified, I'll tell you if I change my mind on manufacturer though.
B.M.800
TheBeal.
Central PA
OK cool, thanks!
I just added pictures to a post I had made a while ago... guess i forgot to look back here.
:p
