Brakes
thaipham25
texas
Am I seeing this correctly... You put a bolt behind the caliper, in between the bracket???
If so, you will wear the brakes quicker than if you left it. These calipers are meant to float in the bracket.
So the cable jacket now still need to be secured, that's why for the main reason it has bad braking.
Really?? When bolt is off the pads, its grinding unevenly and warped. Idk I'm so confused which is the correct way. Oh well ima replace it anyways
Sent from my LGL35G using Tapatalk 2
rmm727
Brookville, PA
I saw two posts that said get hydraulic brakes (which I don't disagree with) but having owned that particular brake caliper, it don't think it should have a problem stop that kart. I have one on my bar stool racer and it will lock the brakes up no problem. I know my BSR is lighter but it should be a sufficient brake for that kart. Could need new pads and the adjusting bolt could be tightened up. Have you tried that?
:iagree:
Yes these brakes are for the most part fine, Willwood makes this for a parking brake caliper and for karting use. (Is this a willwood caliper?)
Now after careful observation of the supplied pics of said machine,
It looks like you have a a good amount of adjustment left in the bolt;
I am however noticing a rub mark on the disc hub. Is there enough clearance for the actuating arm throughout the stroke, as not to contact the rotor?????
That could explain the lack there of stopping power and also the "warped" appearance of things.
Also, is this the supplied brakes, or is this a replacement you bought???
I reckon this isnt the OEM caliper.
I don't normally double post like this, but what's the status of the brake situation.
Also prior to selecting this thread(and looking there 3 times), I noticed this is in the wrong place, as it is a, any other parts.
thaipham25
texas
I got new pads and used cable clamps to tighten cable and tighten up the bracket bc it was warped just a little to where it made the pads grind at an angle.
thaipham25
texas
I also ordered the mcp hydraulic brakes and a e brake handle that should be coming in soon. Only problem i might have with hydraulic is i don't have any room for caliperz and disc but ill figure it out or buy new axle cause the old one is welded and i can't remove
thaipham25
texas
The previous owner welded the bearings and sprockets etc to it won't warp. I prob should go ahead and replace it bc it all rusted and its the only part on this cart i didn't replace. Everything else on the cart is brand new
