On Super Wheels by Carter model 2575, band brake, what makes the brake pedal return? What else should I look for? The rod runs by the frame in a couple places but seems to be bent correctly.
Also, make sure there's no binding in the linkage. Everything should be nice and loose, especially at the front end/at the pedal. Don't forget to lubricate everything with a decent lube.
I use 30W motor oil in one of those old fashioned oil cans. Puts a precise drop or two right where I want it.
