Brake issues
Lsalzano
I have a Coleman ct100u with a disk brake and I am having issues with the adjustment. It makes noise whenever I roll the bike and when I ride it it gets very hot after about a minute. When I adjust the 2 Allen screws to fix it the brake gets very loose and it doesn't help.
pearl111
Baltimore, Maryland
I have the same mini bike I also had to adjust brakes, I think you turned the wrong screws. Send pictures up close of brake maybe I can tell witch screws you need to adjust. I think you turned the wrong screws. Adjust the one that has a nut on it. Loosen the nut turn screw in or out to adjust brake pads then tighten nut,
