hello everyone new here and not computer smart, but here goes, looking for front brakes ideas, I built a custom 58 vette go kart, tons of body work, and custom frame narrowed to fit body over engine as seen in pictures, wanted the only vette kart ive seen so far with engine under tilt body, has predator 212 with all the goodies, kart spins a bit on take off then flys, not looking for top end, built to look like race car, and would like to spin more at car shows, I tried the rear metal pads on the front though, didn't work, tried a kinda e-brake with a rubber pad that drags on ground, not so much, no room to put a disc brake set up on front, as body tight and wheels stuffed under body, engine has governor removed, billet rod, billet flywheel, mod 2 cam, 18lb springs and a tva torque converter, 72 tooth sprocket, spring is coming and was just seeing if anyone has any ideas before I just say screw it and live with it lol thanks AL
