Brake drum will it fit?
Lucky for you, BMI lists the drum specs.
That second drum is right purty--got that thar fancy zinc dichromate plating.
PcKart
I ended up getting a drum that fits. But can't find a large enough band that fits it. I think the drum is not ment to be use with a band. I might just stick with the scrub brake at least it stops both wheel.IMG_1306.jpg
What's the diameter of that drum?
We're here to help... but all these threads about the same kart are confusing.
PcKart
The drum is 5'' the band is also 5'' the is ment for internal brake
