1 tube only? Get a tube at least 1.5".
Muffler? I ported and polished it. Got the threads out. Had 2 holes for a straight pipe. Guess what? I can't find a workable pipe... and I already removed the threads. Darn Briggs...
Anyways... it makes pretty good airflow. If I took the filter out, I'd get probably 3x more. It runs fine without the muffler. It's a shame to put one on. Sounds like a motorsickle
I'd like to see some other ideas though. This was a extremely crude idea created by a 13 year old. I'd like to see some pro work toos
you know this setup might just work but i think it would work better using a smog pump instead of and doing a setup with it. i think this is something im goin to look into but i do like the way you are going but you need to post up video so people can hear it and see it and you need to see what your max is before you do this and after to see what true numbers it makes.other wise it might just be a guess on h.p. gain and not true numbers. remember with out proof no one is going to think it really works.
