Hydro brakes are the way to go because the hose flexes and changing distance is not a factor due to the fact that the hose is cut at a predefined length.
Okay, don't know if I can be more clear... Wrecking yards, auto parts stores, classified ads, motorycle stores, hardware stores, surplus stores, gokart stores, internet...
press the post reply button, select font size 7, select color red, select font "IMPACT", select bold, select underline. then type our writing in the middle of all the code.
then bam!
p.s. can go into more detail (ie pics) if required
Anyways, I don't want to turn this into a bash. I have offered what I consider to be good solid, helpful tips, and I really can't go any further with it. Cheers.
Garage door cable? I know I have that lying around. Anything that's recently heavy will suffice. Thread it thru cone type of housing to protect it. Maybe some hydraulic brake line?
I know yall are goin for brake cables and I see toy story explained it enough but a great ideah for throttle cable is going to a bike shop. They can cut it any length and it you need to cut the shield part use a grinder and cut off wheel. used cable on a truck I had with suicide doors and shaved handles worked great!
