Bogging Down
Warhawk
Senoia Ga
i have a question when i am running my Maxxam 150 2r it will run fine and strong until you go full throttle. any help will be appreciated
Hello and welcome...
Can you post a pic of vehicle in question, what is the motor/mods, gearing ratio... Ect...
mck., it's your standard chinese two seater mini buggy with a 150cc gy6 engine.
gearing ratio is yet undefined to the public.. (because the internal gy6 ratios at least I cannot find anywhere)
Final will by as usual; between 15 and 17 from the CVT to 48 on the axle.
So I'd say the high speed nozzle is clogged in the carb or the setting is off.
Cleaning and resetting the carb is the first thing I'd try.
Also check the fuel and air filter and clean 'em or get a new one just to be sure.
maybe get a fresh spark plug as well.
If that doesn't help I'd check the CVT belt for wear clean and maintain the CVT in general.
It doesn't sound like it, but I'd also check the sprockets and chain for wear while being at it.
And if that all does work as it should I think it's going to be the bigger guns:
compression testing and such ...
PS I'd say it'll be a carb issue.
