Hey thats a good bit more power than a 13hp. The 16 might not have as much RPM potental as an 11 or 13hp, but even left stock you should be able to gear a lower ratio for more top speed and still take off the same or meyby better than a 13hp. You'd have to spend hundreds more to even get close to that much torque from a 6.5 engine.
For a clutch to survive at the 16hp level, you'd most likely be getting into the over $100 price range. With up to 13hp, you could probably get away with one of the lower cost 1" models for awhile. (most of the under $100 / 1" clutches are only rated for use up to 8hp, I've heard of these surviving for a while with 13hp but I'd think a 16 would really be pushing it)
If you wanna research these size clone motors, click here:
http://karting.4cycle.com/forumdisplay.php?f=81 and type GX420 into the search widow.
(I cant remember for sure but you might have to join that forum before you can preform searches)
