Blue engine dies
jonesie8807
my 6.5 hp blue engine dies every once in a while when i pull the throttle on my mini bike. it is pretty new, do i need to break it in more? or adjust something?
rockstomper
It could be the low oil sensor making it cut off.I by passed mine no more problems with that.
Mike
risto
...watches you sleep.
Central Florida
yeah, disconnect the low-oil sensor. that was the first thing i did.
if that's not it, the problem could be a thousand different things.
Magice
I had a similar problem before. It was the mixture on the carb. Maybe play around with that.
Jerryburger
Admiral Annoy
The Nation's Catbox...er, AZ.
It's on the left side of the carb, looking towards the front of the carb, behind a small black plastic square cap. Pull the cap off with needle nose pliers, then adjust the tiny screw with a small screwdriver. make sure the motor is warmed up and running when you do this.
jonesie8807
thanks everyone. ill try the adjustment this weekend probably. ill let u know if it works
