Blown valve spring?
Kenny_McCormic
Kartless....
Michigan Troll
This thing has got me stumped, briggs 5hp flatty, for the most part runs like a yugo stuck in second, wont rev past maybe 3k. Sometimes for no apparent reason it comes to life and runs GREAT(revs up and takes off like a shot while holding high RPM) for a few seconds.
Only thing I can think of is a valve spring broke causing early float and revving the motor just right stacks the pieces increasing tension.
Kenny_McCormic
Kartless....
Michigan Troll
Electronic ignition pack, doubt its timing. Problem with checking the springs is the cover is behind the carb, pulling the carb involves pulling the motor out(TAV jackshaft). I know it isnt the carb, played with setting and just recently rebuilt it.
jr dragster T
Cold place
You never know...It could be timing 100%. One time on my dragster we sheared a timing key and the car would stumble for about 60 feet then run like a champ.
Kenny_McCormic
Kartless....
Michigan Troll
Hmm I wonder if it has any timing marks, I have access to a light. Dont wanna pull the flywheel if not necessary. But it isnt consistent like a shifted flywheel would provide. And if the key semi sheared it would advance it a few and this is a stock motor that would gladly take that.
