Blown Up?
Hadiquddoos
So last night I decided to take the exhaust off of my predator 212 (hemi) I turned the motor on and let it run for approximately 5 mins staring at the motor shooting flames while idling I decided to rev the motor and did so for a little while just being mesmerized by the flames any ways as I was revving it up it died on me, I noticed I was low on gas and decided to fill it up as I tried to restart it, it is very hard to turn over and its not starting, could I have blown the motor???
The engine will run just fine with no exhaust. The problem is as soon as you turned it off the cold air hit the red hot valve. It bent warped or cracked, that's my bet. Sounds like a good time to learn how to rebuild it.
Welp, time to pull it apart and see what's broke/bent.
Sent from my SAMSUNG-SM-G935A using Tapatalk
