blaster carb on 5hp flathead?
Kenny_McCormic
Kartless....
Michigan Troll
It would probably work, you wouldn't gain much without huge valves and a big cam. Being a 2 stroke carb it won't have an accelerator pump, which is why the stock 5hp carb sucks so much.
exit9teen88
member
Hudson Valley, N.Y.
so how about a 4 stroke 150cc or 200cc carb? the cylinder is 206 cubic centemeters when the piston is all the way at the bottom of it's stroke. a 200 cc carb flows enough to fill this. idk let me know.
solomon
ca
Do it, if you buy a better cam, or get some extended lifters, and grind the bottom of ur cam.
Kaptain Krunch
Pro Junk Collector
vermont
That carb is way to big for your flatty nowmatter what kind of cam you got. Small high strung two stroke=huge carb. My rm125 had a 36mm mikuni, my kawasaki kz400 (twin cyl 4 stroke) could handle a single 34 or 36 might be pushin it.
If you want a mik look for something in the 22mm range
