- Messages
- 8,350
- Reaction score
- 3,503
I tidied up a yellowed and stained Bird Baja owner's manual I found on the interwebz. I struggled with creating the PDF as it resized the second page ["General Introduction"] larger than the rest which I think is due to the dpi resolution of the original image. I believe a workaround to this is to open the print dialog and select 'Print to PDF' as the printer. Then select the paper size you want all the pages to be. Then print. You'll get another PDF with all the same size pages.
It should also print normally to paper in 8.5x11 size. Page 12 and 13 were double width in the original image, like a centerfold.
The manual is applicable to other karts and contains general setup, engine maintenance and common sense.
