im looking at gecker motor sport website. They have a few rod options. Could anyone take a look and tell me what rod i need. I am installing the rod for safety at high rpms. I may go with the arc rod in the link you sent me. Good price. How hard is it to remove the wrist pin and reinstall the piston?
I dont know. Ill rev it until it cant rev.I ordered a tach so i can keep an eye on the revs before i get the rod. Ill obviously still use it with a new rod. Right now my engine has a raptor 1 rod. I had to put it in because the other rod and piston were SHOT. Thats a different story. Should i worry about the raptor 1 rod thats being used as a substitute? I am eventually(this is the plan for now) going to get a clone and do some basic work to it. This is for a doodlebug i just got.
note that valve float will probably restrict the engine from reving at some point... installing stiffer valve springs will allow it to run faster... but i wont advise it on a stock rod...
the one linked is NOT billet... and a "aluminium" flywheel is just a cast alu flywheel... if its a billet one it will be written BILLET and it will look like that... both rod and fly here are billet
