big help! - First electric go kart!
baileyboy1
junior builder
help! found a brill motor but its too powerful
thank you camn but i found a good motor but i now need alot of help!
its a 240V 1500W motor! how on earth will i get it to run with a go kart? its over 3000rpm!!
HELP!!!!!:ack2:
baileyboy1
junior builder
i got an old BIZ go kart. it all works but the bumpers are all scratched up and really horrible.
anyway that is my platform for the go kart
Gopedude
Keller, Texas
HELP!!!!!:ack2:
That motor runs of alternating current (house hold electric standard or AC), so in order to make it run off batteries (direct current or DC) you will need to buy a dc to ac inverter. Which complicates things.
If this particular motor is your only option, i can give you some advice on how to hook this up, otherwise i would strongly suggest getting a DC motor.
Canada, AB, Spruce Grove
If you get any motor over 30V you need to be careful, any voltage at 30 or more is considered to be high voltage. I suggest you stick with a 24V motor unless you know what you're doing to prevent a shock. Get a DC motor too, so you don't have to get a power supply to change DC to AC. Don't get a car battery either because if if you get in an accident or a bumpy ride the acid could spill all over you. Reminder that these karts don't have a long battery life (Usually an hour or so). Buy some sealed 12V batteries to keep yourself or anyone riding safe. 40MPH is possible but you would need a LOT of voltage to keep it going (Along with a higher rated motor to keep the voltage/pull the weight).
Gopedude
Keller, Texas
at least 40 MPH. otherwise i might as well stay with petrol! :)
You will be spending wayyy more to get those speeds with an electric setup.
I would suggest getting an petrol engine. It will be a fraction of the cost of electric, and you don't have to wait for it to recharge
If money is not a problem, I'd say go the electric route. Just remember :useless:
