gman3850
He said he wants to make it to 18 or so horse. To successfully get there and not build a complete time bomb, turbo and efi are the safest way to that. And if you look how much everything costs they are about the same.
175cc stroker motor
P&p edrigo head 325
Bbk 61mm 100
60mm stroker crank 170
A12 cam 50
Ncy transmission kit 200
Red spring 20
Dr pulley 11g sliders 25
30mm carb 80
30mm riser and elbo 30
Jerseydevil exhaust 150
Dc adjustable Cdi 50
Jets 30
=1230ish
there is some things i am missing but oh well not let us take out the parts we would not need to achieve better hp and reliability with the efi and turbo
30mm carb 80
Jets 30
-510
now what see the total for the turbo efi motor would be
155cc or 170cc turbo/efi motor
P&p edrigo head 325
Bbk 58.5 61mm 100
cam 50
Red spring 20
Small Engine Fuel Injection kit for Turbo (28mm throttle body) 499
Small Engine Turbo 299
Oil pump 59
Oil cooler 39
Accessories (flanges, gaskets, oil inlet/outlet fittins, fixtures) 89
=1705 + any welding material needed
so for $500 more youd be putting down more and safer hp down
or you can just do an efi kit and still be around the same price without the carb
175cc stroker/efi motor
P&p edrigo head 325
Bbk 61mm 100
A12 cam 50
Red spring 20
28mm throttle body, Small Engine Fuel Injection kit 399
=1439
175cc stroker motor
P&p edrigo head 325
Bbk 61mm 100
A12 cam 50
Red spring 20
30mm carb 80
Jets 30
=1230ish
30mm carb 80
Jets 30
-510
P&p edrigo head 325
Bbk 58.5 61mm 100
cam 50
Red spring 20
Oil pump 59
Oil cooler 39
P&p edrigo head 325
Bbk 61mm 100
A12 cam 50
Red spring 20
=1439
