better than stock?
firemanjim
Just kartin' around....
Houston Texas
Ok, so today, digging through my tool box at work, I found this air cleaner from my sandrail. Would this be better than the stock air cleaner since it has more surface area? I will make an adapter to go from air box throat to air filter that will be tapered from big id of filter housing to air box.
Half-breeder
"Edit" button removed
To find out if it has more area for filtering than what you have/had... (3.14x diameter)x height=filtered surface area. Other than that... Kewl idea! dont see why it shouldnt work well enough... Id paint it and repaint the cooling shroud... 'that' way itll match more and wouldnt be the 'shiniest' item on the kart... lol. But you know me... Mr. color coordinated for the 'blind'...(ie paint it black...ALL of it!)
firemanjim
Houston Texas
Well, my thoughts were to buff the top and bottom, mask off the sides, then painting fire engine red along with the engine cover. That will only leave a hint of bling....
Half-breeder
Thatll work! Alil bling isnt bad... actually helps separate/blend texture differences alot.Good call:thumbsup:!
Fire engine red both, will be good... you gonna undecal it? I think thatll give it a 'cleaner' look(not like you dont know what motor you got). Also, your plastic covering on your carb looks alil dull... Id hit that w/ a shot of black as your doing the other painting... maybe if you got a dremel... while your on call you could take the block to work w/ you and polish anything that looks oxidized(basically make the motor look brand-spankin new! Maybe alil metalic silver for the springs and bolts... just an idea.
qtband
St. Louis, MO
I've had success using ArmourAll on black plastic parts. By using AA, you can leave it all together.
ArmourAll does work on plastic parts but, only for a short time; the clear silicone spray (or tyre shine like this) tends to last a bit longer & won't leave it looking worse once it wears off
Half-breeder
if your against using 'paint' on the carb... theres always plastidip. that way if you dont like it or 'when' you wanna change color... just peel it off.
