Best Overall Cam?
gokarttimmy
Pittsburgh,Pa.
I am building a kart with a 212 Predator Hemi with a stock length billet rod and flywheel-32 degrees advance. It now has a stock RuXing carb, free flow air cleaner, header w/muffler, and Autolite plug. The head and valves are stock. I plan to occasionally take it to a kart track so I can open it up properly. The rear tires are 12.6" in diameter and the gearing is 17t front-80t rear. I need some info on a camshaft and valve springs-it will be run at full throttle a lot, so I'm wondering which combo is best for either all around power or high rpm power. I can change the gearing for shorter tracks or parking lots, so I figure I should shoot for all around power. The kart will NOT be raced in organized events, so I don't have to worry about any rulebook. Thanks for any info.
KartFab
Dallas, TX
I'm no expert, but this info is good.
High rpm cams usually only give you a boost in power across a 1500-2000 rpm range, and poor performance below that range. High rpm cams sometimes require heavier valve springs such as the dual rate springs.
Torque, or marine (for winches) cams give a boost in a broader range and are limited to 5500 rpm (e.g. they will not run above that rpm period).
Mild cams typically see little to no boost in power on the low end, and have a broad increase in power across the rpm spectrum. Single rate valve springs (eg 18 lb springs) are usually run with these.
The cam card will tell you what timing your flywheel should be set to, what springs to use, and what valve lash to set your intake and exhaust to.
Hope that helps. Also, after those upgrades your carb will be the limiting factor to reaching high rpms as it is restricted. This works on the principle of a critical orifice. It doesn't matter how much pressure difference between both openings at a certain diameter, you can only get so much flow.
