Best and cheapest disc brakes?
BrynTen
hey there!
I have recently bought a 6-speed shifter kart that I am currently restoring that has a busted caliper. what would be the best and cheapest double piston caliper for my kart?
thanks!
Joe-405
Enjoying New Projects
U.S.A.
The one for that chassis and brand of manufacturer. Or else it may not work or fit properly.
Got a picture of the caliper by chance ?
MCP caliper. Cast aluminum is cheaper, billet aluminum is a little more expensive, but looks a lot slicker. There are models for 1 or 2 brake lines depending on what kind of master cylinder you have, or you can buy the whole system complete. I get them from BMI.
chances are the calipers on your kart came from the same suzuki donor vehicle ;)
So first check if the RM80 calipers visually match your busted one.
Joe-405
U.S.A.
And this sir is why your awesome. I didn’t even catch that he was the one asking about the leaking caliper. Should merge the two so somebody else doesn’t answer weird also.
If I see a pic I can tell you what it is. I was a assistant manager for cycle gear and I’ve had those dirt bikes. And I’ve had the shifter kart style calipers also. So any pic of the caliper will do just fine.
BrynTen
I have another post asking about a busted caliper, I posted 2 photos on that thread
Thank
